JATO problems
I own a JATO( not 3.3) and it starts easily when its cold but once its warmed up and stalls its extremly hard to start back up[:-] and also needs to be primed alot. Please give me some help
1. Tunning. Get it warmed up and then tune
2. Try a new plug, the correct one for your nitro %
3. Make sure your engine and tank, lines, exhaust are all sealed. Check for leaks.
4. Possibly a bad motor or worn out piston and sleeve.
In case you dont know if you see air bubbles in the fuel its a sign that the line has a hole in it. OR that the engine is getting to hot and boiling the fuel in the carb so it cant enter the engine. That would cause it not to start while hot and make it stall.
