jato 3.3 probems please help!
i was out driving my jato 3.3 and for some reason i couldnt control it anymore (i was to fa out i think) it turned and hit a curb and i looekd it over for damage and i saw that the metal rod that connects to the transmission and the brake system had broken off the trasmission (the small plastic piece that connecrs to the metal rod had broken off the transmission)
i dont know what to do
do i need a knew trasmission case or what?
if you could respondthat would be so good
thanks
thanks
Go here http://www.traxxas.com/products/nitr...xpld-trans.pdf
Right under the words "Transmission Assembly" is that part that you broke. Just look at the pic and figure out which parts broke. Then go to your lhs or order them parts off tower or something.
i see what your saying but i dont know if thats it
i will give you the best description i can
this piece is to the right of the rubber small piece that you adjust for the gear to change (looking from the back)
it is plastic and it connects to the transmission and on that metal piece there is a metal rod that goes into a 90 degree angle to the brake system and out to the front of the car this plastic piece that was part of the transmission broek off it had the metal rod on it
my question to you is will i need a new ransmission case because this platic peice was a part of the transmission
http://image2-6.rcuniverse.com/e1/ga...0/lg-98340.jpg
ok Nick2618, this is from your gallery
do you see the plastic peice to the right of the filter? with the rods? below the gear and kinda like a triangle
its connected to the transmission and it broke off
You either need [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXKMH8&P=7]this[/link] or [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXKMH7&P=7]This[/link] Its kind of hard to understand what you need. I don't understand why you can't look at the link Nick posted and see what part it is.. Because you can have better understanding of it. Find that part and type the number in at Towerhobbies.com
its the second link you gave me
but the plastic piece in the bottom left hand corner
but i am pretty sure that piece connecst to the transmission
thanks for the help
thanks for the help
Well then take the broken piece off and see if its broken under it.. Then go to Towerhobbies.com and type Jato transmission
and then get it.
and then get it.
ok thanks and i was wondering what the best tires and rims to get for my jato 3.3
i want it to have traction on the road and on the grass and stuff
anacondas just wont cut it with the grass
if anyone could tell me that would be good
