RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
engine
Old 10-19-2008 | 10:36 AM
My Feedback: (-2)
Default engine
hi there ,new to this .can you install a gt2 engine into gt 1.
Old 10-19-2008 | 11:24 AM
Default RE: engine
you can put whatever small block engine you really want in either vehicle, you just need a different clutch setup and quite possibly a different throttle linkage if you switch between slide/rotary.
But, to keep things simple, just get a short shaft engine with a rotary carb for the first gen GT.
Old 10-19-2008 | 08:19 PM
Default RE: engine
i personally would recommend a slide carbie. the linkage is very simple for that also. the low end response of the slide really compliments the gt1's low weight.
Dann
