Best way!!!?
WA
Best way!!!?
I just wanted to know what people think of the best way in shutting off nitro engine??? I say go with pinching fuel line. what do you guys think???
NJ
RE: Best way!!!?
personally i put my finger over the stinger. I never had flooding problems. some people say piching the fuel line it bad because you lean it out for 3 seconds whick i dont think it affects the motor.
GA
RE: Best way!!!?
Putting your finger over the stinger on a small block is no problem but if you have a big block you will burn your self. I like to stop it by the flywheel with either my finger with gloves on or with my foot through the slot for a starter box.
CA
WA
RE: Best way!!!?
When i watched the video about shutting the engine off they said that leaning the engine is bad which is true. But thats what i have been doing for a long time but maybe hitting the flywheel is better but doesn't remove all that nitro in the engine making the engine rust.
