Slipper/ Clutch question
Sry if I am clogging up the forums, but I just put a new motor in my rc10 gt and I was just wondering what the right amount of clutch bell, slipper mesh was. Also the way I have it now the truck does not roll very freely and i have to give it a good push. Do I have to move the motor forward or back or maybe adjust the slipper?
RE: Slipper/ Clutch question
You should have alittle bit of play between the gears. Use a bit of paper between the gears and push them together.
Pull the paper out, that should be the right amount of mesh.
If your truck wont roll, the drive-line could be bound up. Check your wheel bearings, and transmission bearings.
