RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Shock oil...
Old 03-07-2009 | 08:16 PM
Default Shock oil...
dont know what weight oil should i use on the shocks.?? i have right now 30 in te front and 60 on the rear the rear seems fine but the front is all over the place.. Any advice would be appreciated Thanks.
Old 03-08-2009 | 02:43 AM
Default RE: Shock oil...
I think you shouldnt have such different weights... maybe 50 - 60? or 50-50¿
Old 03-08-2009 | 01:16 PM
TGreg's Avatar
when you say all over the place you mean bouncy? if so, your springs are to heavy and your oils to light. try using a lighter spring rate and a thicker oil, maybe 35 or 45.
on another note, 50/60 seems kinda heavy oil for stadium trucks.
Old 03-08-2009 | 02:32 PM
what really happens is that it flips too much, i also got the sway bar kit. it hits the jups reeall good
and i need adjust the gear when i in the straigh in the track it hits second at the end of the straight and always go off the track. is clockwise shorten the gears or the other way??
Old 03-08-2009 | 03:26 PM
My Feedback: (8)
A Slayer is notorious for flipping, pretty much all they do when turning at speed. As far as the transmission shifting sooner or later check the sticker on the transmission it tells you which direction to shift sooner. If the sticker is gone check the manual it will say in there. I cant remeber since I got rid of mine a few months back.
