Now that I've switched my fuel...
Of course you know that it doesn't run the same. My question is should I buy a whole new engine or can I just replace the carb for my duratrax evader?
CA
RE: Now that I've switched my fuel...
ORIGINAL: MonteEvader
I see the confusion. Let me clarify, I've switched from 20% to 10% fuel. Does that change the answer? It's impossible to tune.
i went from 20 to 30 percent without a prob. all u have to do is play with the needles. u r runing a lower percent nitro so there is no way that those needle settings r going to work for less nitro%. if im not mistakin u will have to lean it out bacause of the nitro percent. i could be wrong but if i am im sure someone will correct me.
