please help jato clutch?????
ON, CANADA
i got a new clutch for my jato and im not sure how to install it .i got a 3.3 Li-Wt Flywheel 3 Clutch system from hot racing ,i read that its a good clutch but dont know which way the shoes go and how the springs go on. also there is six little washers were do they go and there is also a gold cone like piece .please help me . if anybody also has pics of the install would be great
[link]http://www.hot-racing.com/?partnumber=TRX100S306&c=180[/link]
GA
RE: please help jato clutch?????
Here's a link to the 3.3's assembly views. http://www.traxxas.com/PDF-Library/TRX33_explode.pdf
The gold cone secures the flywheel to the shaft. The six little washers are used to shim the clutch shoes so they sit properly in the clutch bell. The shoes should face the same direction as the old ones. If you install them backwards, you'll know it, the truck will be very noisy and probably won't move.
