tires?
CA
RE: tires?
ORIGINAL: Nitrohobo
hey guys im looking at pro line right now and what 30 size tire do i want for hard dirt like clay hard
CA
RE: tires?
Why don't you stick to answering the question instead injecting a bunch of BS.............not one of the tires you mentioned are 30 series tires [:-]
CA
RE: tires?
ORIGINAL: rclynx
RE: tires?
ORIGINAL: Chris_RC
Yes, but all of the tires I mentioned will be better than Proline 30 series tires (2.8 wheels). If you go with a tire with 2.2 wheels there are more options available and more traction. Badlands would work horrible on that terrain. Bowties would work ok but there would be alot better choices.
ORIGINAL: rclynx
CA
RE: tires?
ORIGINAL: quietnas1
Tend to disagree. The 30 series Badlands have great traction. I use them on clay, dirt , and grass. And on clay I still manage a wheely every now and then. Great tire, great grip.
ORIGINAL: Chris_RC
ORIGINAL: rclynx
NH
RE: tires?
badlands? only time id ever think about using that tire is on a crawler. not putting down anyones suggestion. but that tires tread patters and diameter is much too large. on a hard surface it would have a lot of slop, causing the truck to feel very "loose". our track is a hard packed loam/dirt surface (rock solid in the groove and loamy everywhere else). in my opinion something more "pin-like" would perform better such as lugnuts, step pins, or bowties. personally i use lugnuts. the trick is getting the right compound for your track.
RE: tires?
yeah im going to get a pair of one of theses Switch 2.0, Pink Taper Pins, maybe Holeshots not sure yet but its going to be for only hard dirt im saveing these tires for the track so i realy want a pair that can hook up not plaining to use every were just hard dirt clay like hard
RE: tires?
ORIGINAL: usa98030
TOTAL BS! go with the bowties for racing and badlands for bashing!
CA
RE: tires?
ORIGINAL: Nitrohobo
