Jato help..
Jato help..
I am replacing the rear suspension arm, the rear suspension pin mount, and the shaft assembly for the first time.... it looks a little difficult, anyone have any insight or a step by step?? thanks
RE: Jato help..
Ok in order to remove the arms you have to take a few steps. It sounds like a lot but its pretty easy. 1) Remove the rear baterry cover. 2) Remove the wheelie bar. 3) Remove the diff cover screws including the 2 in the battery box. 4) Remove the rear most screws under the chassis that hold the diff cover in place. 5) Once the diff cover comes off you can remove the rear A arms and the other stuff you need as well. Make sure before you start removing this stuff that you remove the turnbuckles and the shocks.
