3.3 rustler
3.3 rustler
is there any way to up the gear ratio on a nitro rustler i have a 3.3 in it and even with the max pinion and smallest spur they make for it its still geared to low.
i had to shim the engine to get it to fit with the smaller spur, is there another set of gears that would work on it to up the top speed?
RE: 3.3 rustler
im already at 24 on clutch bell and i think the spur is 66 tooth, i would like to get it around a 27/65 ratio but the rustler gears dont go that high and the engine may not line up right.
i couldnt get my jato working for the 4th just too many pieces.
