RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
XTM .18 help
Old 08-02-2009 | 11:12 PM
GW
Default XTM .18 help
XTM .18 Engine: Ran good last time out. This time nothing but issues, starts run a bit then just quits. Thinking the carb my need cleaning?
Need to know:
Is this the right course of action?
How do I get it back to factory carb settings
Best way to clean carb ?
THANKS!!
Old 08-05-2009 | 11:30 AM
GW
Default RE: XTM .18 help
I found the info.
Just FYI in case anyone else needs it:
Factory Setting on XTM .18
Low speed, all the way cloockwise until it stops then backed out 5 turns
High Speed, all the way clockwise until it stops then backed out 3 turns
Old 08-05-2009 | 01:01 PM
larryf333's Avatar
Check for air leaks too, around the carb and the rest of the engine. Is the exhaust header held on by springs or screws? If it uses screws, they will back out almost every run, unless you clean the area good and use loctite.
