Help. Jato rear diff lube?
I recently replaced the rear diff housing on my Jato because of a broken turnbuckle mount. There was very little lube in the old one. My question is should i put some in the new one or not before putting it all back together? If so, how much? Any insight would be appreciated
MN
RE: Help. Jato rear diff lube?
yes use some Traxxas white grease. just install the gears into 1 half of the trans and put a dot of grease on each gear, then rotate the gears slowly until all the teeth have a light coating.
