Differential Fluid for jato
NJ
I did a search but didnt find anything that related directly to the jato. I have the jato 3.3 and my differential cover cracked. A little fuild, more like grease in texture leaked out. I took the whole cover off and replaced it. Inoticed there was still "grease" in there on the gears but not swimming in it. Should there be ALOTof fluidin there as in filling the wholedifferential comparment? Or just enough to make sure all the gears are covered well? Also if Ineed to add some what would be the best kind to add? I know there make different viscositys of the fuild and im mostly looking for whatever they put in there stock or will work better then stock.
Thanks!
Thanks!
