EVADER
ok guys been in this about 10 years .. have had all kinds. but my evader rear diff will not stay tight.. even red lock tighted it and after setting for 2 months weather. went threw about half a tank of fuel and loose again this makes about 4 times what am i doing wrong
This was an issue with some evaders, I rememebr on the original evader thread that there was a fix, I can't remember what it is & the thread is hundreds of pages long. You could do a search on diffs on that thread & see what you come up with.
I remember the slipper had this issue which was solved by using 2 nuts, the first wound on to set the slip amount & then the second screwed onto the first one & tightened up to stop it backing out. Could it be the slipper & not the diff?
