RCU Forums
-   RC Nitro Stadium Trucks (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/)
-   -   Nitro Rustler (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/10284955-nitro-rustler.html)
sourya 01-24-2011 11:05 AM
Nitro Rustler
Hi,
I got a great offer on a secondhand TRX3.3 .
ATMi am running a TRX pro .15. I am wondering is it worth the upgrade and what do i need to buy, like exhaust or linkage.
The TRX 3.3has run 2.5 litres of 20 nitro.
Can u guys help me out
MPevine11 01-24-2011 01:59 PM
RE: Nitro Rustler
i just got a 3.3 for mine also ( i had the 2.5 so its a direct drop in)
but this is what you need
[link=http://www.amainhobbies.com/product_info.php/cPath/1_25_1466_660/products_id/17771/n/Traxxas-Nitro-Rustler-Pro15-to-TRX-25-Upgrade-Kit?utm_source=Google-Base&utm_medium=cpc&utm_campaign=Product-Feeds&source=google_ext]Click Here[/link]
Details:
part #TRA4400
Traxxas Nitro Rustler Pro.15 to TRX 2.5 Upgrade Kit
PRICE: $22.49
All the necessary hardware to bring older Traxxas models up to full TRX 2.5 spec is included such as; header, pipe, pipe hanger, coupler, linkage, and additional components specific to each model. Major components come pre-assembled and pre-adjusted from the factory. Detailed instructions are included for each. TRX 2.5 Racing Engineā„¢ (model TRA5207) sold separately.
get the upgrade kit to add a 2.5 as posted above. because the 3.3 takes the same linkage and mount.
1QwkSport2.5r 01-24-2011 06:09 PM
RE: Nitro Rustler
Really, you can save the $23+shipping on the kit and buy just the throttle linkage for the 2.5 rustler. I cant imagine this would be more than $5. Use the rest of the money to buy a decent pipe for the engine. The black plastic pipe that comes in the 2.5/3.3 conversion kit is a piece of junk. I bought a TRX blue alum. pipe for $25 new, a header, and the carb. linkage and I was set. The kit sounds like the better deal, but IMO its not. You could probably find most of the parts seperately on the 'bay for a heck of a lot cheaper.
MPevine11 01-24-2011 06:33 PM
RE: Nitro Rustler
get a THS pipe or Buku if you want some power!
sourya 01-25-2011 03:29 AM
RE: Nitro Rustler
but wont it mess up the drivetrain because it is all stock?
MPevine11 01-25-2011 01:42 PM
RE: Nitro Rustler
i had a rustler 3.3 all i did was MIP cvd's
as long as you dont throw huge tires on youll be fine
sourya 01-26-2011 03:50 AM
RE: Nitro Rustler
ORIGINAL: MPevine11
what do u mean with MIP cvd???
<br type="_moz" />
1QwkSport2.5r 01-26-2011 06:52 AM
RE: Nitro Rustler
ORIGINAL: sourya
ORIGINAL: MPevine11
<br type=''_moz'' />
MIP cvd's are metal driveshafts that replace the plastic ones. A 3.3 will eat the plastic ones for dinner. I ran the same set of cvd's for 6 or 7 years. I would have replaced the plastic ones a dozen times or more in that time.
MPevine11 01-26-2011 01:45 PM
RE: Nitro Rustler
heres a link
http://www.amainhobbies.com/product_...rce=google_ext
1ofmyfuns 01-31-2011 01:11 PM
RE: Nitro Rustler
Will this MIP cvd's kit also work on the Nitro Sport Pro.15?
Ihave one Iwant to upgrade to the 2.5 engine in the futureand thought this kit would be a good addition if it will work on the Nitro Sport.
Thanks in advance
sourya 01-31-2011 01:27 PM
RE: Nitro Rustler
the guy who had the 3.3 sold it already...
Now i m looking into a picco or something. Any advice?
MPevine11 01-31-2011 01:40 PM
RE: Nitro Rustler
OS .18 TM would be nice
OR
OS .21 TM (may be to much power)
378 01-31-2011 06:18 PM
RE: Nitro Rustler
An OS 18 CV-RX(S) would be a direct bolt-in and would give you just as much power as the 2.5 would have. The Pro-15 is rotary carb side exhaust, so an 18 TM would require buying the 2.5/3.3 retrofit kit. The CVR would not.
sourya 02-04-2011 05:21 AM
RE: Nitro Rustler
So if i buy LRP Nitro Engine Z.18S Pro Spec.3. I would not need a conversion kit ( different engine mounts)?
Are these good engines?
I know i ask alot, but it would be stupid to buy something and not be able to use it.
1QwkSport2.5r 02-05-2011 08:06 AM
RE: Nitro Rustler
ORIGINAL: sourya
If that LRP comes with a slide carb, you'd have to change the carb linkage if you currently have a pro .15. The .18 engines are smallblocks, so it should mount fine. Might I suggest a Dynamite .19T. This is a 2.5/3.3 direct replacement and is cheaper than the OS.
Dynamite 2 .19T $110:
http://www.amainhobbies.com/product_...ide-Carburetor
OS .18TM $150:
http://www.hobbyfever.com/product_in...oducts_id=4153
