RCU Forums
-   RC Nitro Stadium Trucks (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/)
-   -   engine problem (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/1622988-engine-problem.html)
Nitro Rustler Racer 03-14-2004 10:26 AM
engine problem
i have had a Nitro Rustler for 2 years, with a pro.15 in it. i never had problems until i, i moved to a different state. for some reason when ever i try to start it the engine will start backwards. i have to restart it like 4times to get to go forwards. can anybody help me
ICrashThings 03-14-2004 10:28 AM
RE: engine problem
on my RC controller i have a little switch that says "rev" for reverse...does your controller have the same thing? if it does switch it to the other side...thats the only thing i can think of doing...
ericheller 03-14-2004 01:40 PM
RE: engine problem
ORIGINAL: ICrashThings
im guessing he means that the engine is actually spinning backwards.
rustler: how do you start your truck?
^^_FaWaZ_^^ 03-14-2004 02:23 PM
RE: engine problem
think u busted the thing called the (one way clucth set) and (starting axle) it happend to me once but dont start it oftenly coz it will damage ur engine.
Nitro Rustler Racer 03-14-2004 07:57 PM
RE: engine problem
how i start it is, first i take the plug out flip the car over and spin the engine over to get after run oil out. then i put the plug back in with the washer, then i pump fuel into the carb and put the glow plug heater on. then i just pull the pull start and if it dont start i put my ginger on the exhaust tip
ericheller 03-14-2004 08:54 PM
RE: engine problem
ORIGINAL: Rustlerraceer
hmm, thats weird then that it would run backwards. your truck doesnt have reverse right? or does it? have you taken the pull start off lately?
Nitro Rustler Racer 03-14-2004 09:32 PM
RE: engine problem
no, i doesnt have reverse, the last time i ran the truck was about 2 weeks ago was the last time i took the pull start of cuz the one-way bearing was slipping because it got oil into it
ericheller 03-14-2004 09:37 PM
RE: engine problem
theres your problem, you must have the one way bearing and pull start backwards or something.
leandro 03-16-2004 11:38 AM
RE: engine problem
if it has a electric starter it couldnt be that u instaled the pos into the neg i own a rustler also but it never happend to me so i might be right.
rushdude 03-16-2004 01:35 PM
RE: engine problem
Ericheller is right. Put the one way bearing back in the pull start or buy another one and it should be fixed
Nitro Rustler Racer 03-16-2004 04:04 PM
RE: engine problem
i took my one way bearing of it seams fine. i cleaned it, then i started the truck runs fine. gues sometine else.happens again,i will just get a new one way bearing
