46.conversion kit?
hiya, ive bin web surfinn and had a look on hotbodies site and came across a 46.conversion kit for the savage?,surely if you put an engine that size with that power in a savage it would rip it apart?
RE: 46.conversion kit?
wrong forum there buddy, i suggest moving this to the savage forum. but im guessing that the .46 you speak of is a 4 stroke. if so i wouldnt do it, it will be slower, maybe a little more torque.
thanks was just wondering wat would happen. (i havent got a savge by the way just a hardy lil rc10gt)
oh ok i see. i dont think it would work for a gt if thats what you mean, because the savage is ment for a big block, and the .46 would be even bigger. a .46 would have alot more low end torque than a small block such as the one on your gt, but you would really have to change the gearing to achieve the same top speed. im guessing that it wouldnt be possible to gear it to do over 30mph with a .46
ORIGINAL: ericheller oh ok i see. i dont think it would work for a gt if thats what you mean, because the savage is ment for a big block, and the .46 would be even bigger. a .46 would have alot more low end torque than a small block such as the one on your gt, but you would really have to change the gearing to achieve the same top speed. im guessing that it wouldnt be possible to gear it to do over 30mph with a .46 I am surprised a mod hasn't moved this yet. |
are you sure its a 2 stroke? alot of those 4 stroke airplane engines use mixed fuel just like 2 stroke engines.
Yeah its a two. Look at the heads, if it is a pushrod motor with valves, they stick out like a sore thumb.
hey, my friends dad has a savage with a .46 in it, but he doesnt even play with it cuz hes stupid or somehtin. He has over 1,000 in that truck alone and never played with it once.
ORIGINAL: spidster hiya, ive bin web surfinn and had a look on hotbodies site and came across a 46.conversion kit for the savage?,surely if you put an engine that size with that power in a savage it would rip it apart? |
the truckzilla is a 2stroke 4.8 hp 23.000 rpm short stroke with very hi compression. they suggest using gloves for the pullstart for the first 10 11 tanks and lossening the glowplug till it starts. I just want to know the maufacturer.
1 Attachment(s)
here is a picture
| All times are GMT -8. The time now is 08:05 AM. |
