RCU Forums
-   RC Nitro Stadium Trucks (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/)
-   -   Engine PROBS!! (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/2604153-engine-probs.html)
nbcaznmaster 01-31-2005 06:26 AM
Engine PROBS!!
Everytime i start up my rusty, the engine idles for a while then shuts off. IS it just tuning problems or coudl it be other problems w/ the carb or the engine.
nitro monkey 01-31-2005 08:08 AM
RE: Engine PROBS!!
is it winter bc it might be running to cold
-Ryan
Nitro Rustler Racer 01-31-2005 10:48 AM
RE: Engine PROBS!!
try raising up your idle, and are you running it rich? if you are then lean it a little bit, or when you start it dont let it idle
tbns05 01-31-2005 11:23 AM
RE: Engine PROBS!!
I had that kind of thing when I tried running my truck (RC10GT) in the snow last week... It was really cold outside... I eventually gave up because it wouldn't start, however the next time I wanted to run it I ended up making the mixture much more rich -- worked great... The cold weather really makes a difference.
Now that I think about it though... that doesn't make much sense as you'd think the cold weather would keep the engine cooler meaning I could run with less fuel in the mixture.... Hmm.... [&:]
ncgrunt 01-31-2005 02:42 PM
RE: Engine PROBS!!
Cold air is more dense. If don't touch your needles and go from a warm/hot day to a cold day, your mixture will still be more lean.
mittimj 01-31-2005 09:43 PM
RE: Engine PROBS!!
I was runing my rusty when it was about 10f out the other day and I had to richen it out about 1 turn of the high speed needle to get it to run at all.
