RCU Forums
-   RC Nitro Stadium Trucks (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/)
-   -   Throttle in reverse? (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/2650873-throttle-reverse.html)
Satyr69gt 02-12-2005 07:07 PM
Hey people!
As you can tell I'm a newbie so this may be a stupid question, Have a Hitec Tx and had to buy a new hitec reciever. After gettting everything together the steering worked fine but the throttle wide open! Tried turning off & on a few times to see if that would help. No go. The servos are futaba. Cant figure out. Any suggestions would be greatly appreciated
Thankx
P.S. This is on a RC-10Gt if that helps.
nitro monkey 02-12-2005 07:55 PM
RE: Throttle in reverse?
check ur trottle trim
-Ryan
BaSh_2_tHa_mAxX 02-12-2005 07:57 PM
Take your servo horn and and centre your throttle trim and then centre your idle.
Satyr69gt 02-12-2005 08:17 PM
Thankx for the ideas but I found a lttle switch on the Tx that was set to normal, Switched to reverse and all is good! Is it a positive & negative thing when you use different brand servos or is it just with futaba Tx's & Rx's? that it acts like this. As I said I'm a newb to nitros so I will probably ask alot of stupid questions for a awile till I get a little bit more knowledgable, so bear with me;)
Thankx Again
