help
i got some new rims and i need some help getting the tires off the old rims
RE: help
try using some acatone which is nail polish remover.
RE: help
and a x-acto knife if things gets really bad. Also some strong fingers can sometimes rip the bead off! I know have on occasion!:)
RE: help
Boiling water works.
RE: help
Yep boil water and stick them in it it should disamble most of the glue
RE: help
if there is a spot that isnt glued then what i do is take a small flat head srewdriver and slide it along the bead of the tire.
RE: help
If your going to boil your tires to get rid of glue, watch them closely. and try not to let the tire rest on the bottom of the pot.
if so then you'll have rubber soup. You only want to heat up the glue so you can get it off the tire. nothing else. I know guys that have ruined tires this way so be careful ;) Tweedy |
RE: help
ORIGINAL: rc10gbash try using some acatone which is nail polish remover. And as Tweedybird said don't go and run off or else you have a rubber plastic soup. |
RE: help
boiling water
RE: help
thanks... the water worked
| All times are GMT -8. The time now is 11:54 PM. |
