fuel for nitro evader st...
My evader st is comin in soon and all i gots now is 10% fuel. is it ok if i use 10% in the car until i get some 20%?:D
RE: fuel for nitro evader st...
ya but after you get 20% nitro i think you might have to richen your carb.
you will have to run the engine in again on a different fuel to get it suited to it, just do 5runs on a rich carb setting at no more than 3/4 throttle, once you have done 5 runs with it start to lean it out again until you get perfect tuning (good speed and not alot of smoke)
cant i just use 10% with it for a bit then change to 20% and change my settings a bit?...do i have to do the 5 tanks thing?
You should so that it is at its correct level. you wont know until you run it for the five tanks.
10% is okay, but watch your temps. That low of nitro and it will need to run leaner to run properly. Keep a sharp eye out for overheating.
Is the evader you're getting new or used? If it is new, you will need to break in the engine properly. Switching back to 20% whenever you can will be fine. It will need to be run richer. There's no voodoo to switching fuels. The best way to do it would be to set the carb back to factory specs, fire it up and tune from there. There's no reason to break it in again on a different fuel. |
i didnt know that
