HELP, PLEASE
I have a RC10GT and just bought the OFNA throttle/brake linkage kit(the whole deal).....and it doesn't come with instructions and i can't seem to find anything online.....can someone tell me how to put it together, and if you have pics to show with it that'd help alot...thanks alot
RE: HELP, PLEASE
someone post please
RE: HELP, PLEASE
no ones posing because they probabley dont have any clue as to what your tlking about
and if its any help likages are suposed to be hard and imposible to put togethere |
RE: HELP, PLEASE
1 Attachment(s)
I got the Duratrax linkage kit but I think they are the same. I hope these help you:
RE: HELP, PLEASE
with the ofna kit there is one long thin metal bar and it's straight....am i supposed to use that for the throttle part and use the old brake peices with the kit?.......the duratrax one does look quite similar maybe exactly the same, but am i supposed to cut that bar shorter or what?
RE: HELP, PLEASE
Thats exactly what I did:
1 Re-used the old brake linkage and 2 Cut the straight linkage provided with the kit to fit for the throttle. The only tricky part was that I had to loosen the nut that holds the throttle linkage to the servo horn a little bit to keep it from binding. |
| All times are GMT -8. The time now is 02:23 PM. |
