RCU Forums
-   RC Nitro Stadium Trucks (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/)
-   -   problems tuning jato (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/3410949-problems-tuning-jato.html)
altjohns 09-30-2005 11:45 PM
when i try to set my high idle it starts to not run at all. when i get it running again it's too rich and cuts off when i go wot. i have been messing around with the high and low idle adjustments the most, could the idle affect this problem any??? i'm in need of a little help, this is pretty frustrating.
jatodriver 10-01-2005 01:55 PM
RE: problems tuning jato
set the low speed to factory setting, dont mess wit it, just mess with the high speed
altjohns 10-01-2005 09:45 PM
i'll try it
46u 10-01-2005 11:05 PM
Set the high speed needle first then the low but not till you have the HSN set correctly. If you do not adjust the low you will not get the best performance out of it. All so it can change day to day.
altjohns 10-02-2005 02:24 AM
yeah i know it changes with weather and other small things, plus i hear these 2.5's are real touchy to say the least. i'm plottin on gettin a new engine sometime in the future. thanx for the info.
Midget 10-02-2005 05:39 AM
i would losen the low speed like half a turn or put it back to the factory seting becuase if its ceeps on staling it sownds like it's not geting any fuel.
if this dosent work see if the fuel line is craked it might be sucking in air so theres only air going to the engein not fuel
hope this helps:D
altjohns 10-02-2005 05:46 AM
i checked the line and its good, i believe my idle screw maybe stripped out. not completely but it doesn't stop anymore. could this be part of the problem??
Midget 10-02-2005 05:57 AM
have a look at ur carby and turn u controler on and put the brakes on if lol carby shuts then yes its striped.
if this is the case then put the trim up a bit on ur controler and see if the carby opens then dont use the brakes\
and try and start it.
and just a quetion is ur JATO new
altjohns 10-02-2005 06:14 AM
yeah, its only about six weeks old or so. and yes it does close when i hit the brakes. i already set the trim on the control to get it started w/o the brakes.
Midget 10-02-2005 06:20 AM
ok then
with the idle screw take the servo horn of off the servo(this bit that has ur brake and caby levers on)and use ur hand to hold open the carby about 1mm or so and titen the idel screw up, then after this conect it all up again and put the brakes on if the carby closes then
im sorry i cant help u any more
altjohns 10-02-2005 07:03 AM
its good it holds carb open. thanx.
Midget 10-02-2005 07:48 AM
oh thats good im glad its fixed:D
