RCU Forums
-   RC Nitro Stadium Trucks (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/)
-   -   priming engine (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/4230013-priming-engine.html)
wyumez 05-01-2006 09:40 PM
priming engine
I was tuning my 18ss engine today and when I prime the fuel, it won't go to the engine, I mean, I'll press it, it touches the carb, then it'll sizzle, then come back an inch or two.. rinse and repeat. I've tried blocking teh stinger with little success but not much =/ Is the reason behind this is too lean of a setting?
thanks in advance
yznaction 05-02-2006 12:45 PM
RE: priming engine
Is this after youve run you motor, Because if it is then its probably just vapor lock. If it does it before youve run it when the motor is cold, then you have a blocked needle of a leak.
Nitro Rustler Racer 05-02-2006 04:05 PM
RE: priming engine
easy way to prime, put finger on the exhaust pipe, and pull the pull start. you will see the fuel going. If that doesnt help or what yznaction said then you may have a air leak that sucks it back to the tank
wyumez 05-02-2006 04:09 PM
RE: priming engine
yeah, this is after I ran the truck a few. It was working today but I lost a freaking screw on my right knucle.. again ::sighs::
