RCU Forums
-   RC Nitro Stadium Trucks (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/)
-   -   new engine (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/4267253-new-engine.html)
houserfan1980 05-11-2006 04:21 PM
new engine
is it normal for your engine to die while idling? this is my first tank of fuel on the motor. the only way i can keep it idling is if i prime the engine..should i adjust the high speed needle? thanks.
46u 05-11-2006 04:46 PM
RE: new engine
I would try to set the idle up a little. If this cause it to idle to fast try leaning out the low speed a little. What engine do you have?
houserfan1980 05-11-2006 04:48 PM
RE: new engine
thanks..its the tower hobbies .15abc whatever motor comes with the st-15
46u 05-12-2006 12:18 AM
RE: new engine
Whats it doing now? [8D]
ryan_t888 05-12-2006 11:13 AM
RE: new engine
ORIGINAL: houserfan1980
If you need to pump fuel in to the engine to keep it running it is running lean. Richen the LSN on the carb and see if that helps. I had the same thing with my .15X, the LSN was way too lean from the factory.
Ryan
