jato is durable
if any ones gets the jato its is super durable but before u take it off crazy jumps get rpm arms for front and rear. i only got rear and the front snaped a little bit............................................... ..........
RE: jato is durable
...... yea ..?
RE: jato is durable
RE: jato is durable
It's just as brittle as every other stadium truck.
RE: jato is durable
ORIGINAL: 46u No broke shock towers yet? You are doing good. http://www.rcuniverse.com/forum/m_4464848/tm.htm I don't know why you insist on saying the Jato shock towers are weak. 1 Person claimed that and it was a dolt who had the suspension adjusted so tight the shocks didn't move thats why the towers break. I own a Jato since it came out and run it every week and have yet to break a shock tower. Perhaps buy a Jato first then comment on it. |
RE: jato is durable
ORIGINAL: Valve It's just as brittle as every other stadium truck. |
RE: jato is durable
ORIGINAL: badz ORIGINAL: 46u No broke shock towers yet? You are doing good. http://www.rcuniverse.com/forum/m_4464848/tm.htm I don't know why you insist on saying the Jato shock towers are weak. 1 Person claimed that and it was a dolt who had the suspension adjusted so tight the shocks didn't move thats why the towers break. I own a Jato since it came out and run it every week and have yet to break a shock tower. Perhaps buy a Jato first then comment on it. I'm tired of people posting comments about cars/trucks that they don't own. |
RE: jato is durable
Just because somebody doesn't own the truck doesn't meen they don't have experience with it. I personally work at a hobby shop so I have a lot of experience with each truck. You wouldn't beleive how many people come in with Jato problems. Broken top plates, broken servo cases, snapped shock towers, broken arms. It happens. Most STs are built the same way. How much more durable can one be compared to the other? It all depends on the way people drive.
RE: jato is durable
ORIGINAL: Valve Just because somebody doesn't own the truck doesn't meen they don't have experience with it. I personally work at a hobby shop so I have a lot of experience with each truck. You wouldn't beleive how many people come in with Jato problems. Broken top plates, broken servo cases, snapped shock towers, broken arms. It happens. Most STs are built the same way. How much more durable can one be compared to the other? It all depends on the way people drive. you have a point there, mine has broken two front arms and a rear shock tower because of my stupidity not because of faults in the design |
RE: jato is durable
Hey its the DOLT from the other forum whom you ASSumed didnt know how a stadium trucks suspension is set up. You should watch what you say about people Badz.[:@]
RE: jato is durable
i believe you are talking about me when you say about that guy that breaks shock towers, at least if you break something you can go to your lhs and get a new one, i CANT, i dont have a lhs, so i always have to order new stuff, i tightend my shocks, because i wanted to beharder, i cant order better spring everyday.
btw, 46u didnt say anything bad, i dont what is the problem. |
RE: jato is durable
ORIGINAL: crazyjr ORIGINAL: Valve Just because somebody doesn't own the truck doesn't meen they don't have experience with it. I personally work at a hobby shop so I have a lot of experience with each truck. You wouldn't beleive how many people come in with Jato problems. Broken top plates, broken servo cases, snapped shock towers, broken arms. It happens. Most STs are built the same way. How much more durable can one be compared to the other? It all depends on the way people drive. you have a point there, mine has broken two front arms and a rear shock tower because of my stupidity not because of faults in the design I sorry I most of misunderstood you the last time you broke one at the track as I thought you told me you broke them all the time and is why you keep 2 in your pit box. |
RE: jato is durable
ORIGINAL: Valve Just because somebody doesn't own the truck doesn't meen they don't have experience with it. I personally work at a hobby shop so I have a lot of experience with each truck. You wouldn't beleive how many people come in with Jato problems. Broken top plates, broken servo cases, snapped shock towers, broken arms. It happens. Most STs are built the same way. How much more durable can one be compared to the other? It all depends on the way people drive. i jump mine like 20-25 feet in air with out body and i dont break things |
| All times are GMT -8. The time now is 12:53 PM. |
