RCU Forums
-   RC Nitro Stadium Trucks (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/)
-   -   Engine wont unflood (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/4810669-engine-wont-unflood.html)
troll2000 09-30-2006 08:35 AM
Engine wont unflood
I have a rush evo with a t-15 engine in. when i try and start it the pull starter is very stiff. I took the glow plug off and pulled on the pull starter and tipped it upside down but only a few drops of petrol came out so it is still flooded! is there a different way of unflooding it or is it something else all together please help
Wide Open 09-30-2006 08:53 AM
RE: Engine wont unflood
wait, did you put actualy petrol/gasoline in it??? thats the thing you dont want to do! lets at least get that sorted out before anything else;)
Steve455400 09-30-2006 09:02 AM
yea you do not whant any petrol/gasoline is these Nitro modled engines. If it keeps flooding try replacing the glow plug cause a worn out glow plug won't ignite the fuel when weakend or damaged and it will cause the engine to continue flooding. If this doesn't help you may need to check your engine cause if an engine bering is worn out it will cause the crank to of center and make it hard for the starter or check the flywheel a bent flywheel would make it hard to pull the starter. try these I hope they help.
troll2000 09-30-2006 09:14 AM
no its not petrol its the propper nitro car stuff. I guess i could order a new glow plug and try it in a couple of days
Hotdam 09-30-2006 09:20 AM
Well you say you pulled the pull start then turned it upside down , need to have it upside down while pulling the pullstart through a few times. You can check your glowplug by hooking your igniter up to it for a few secs and see if it gets hot. hope this helps.
troll2000 09-30-2006 09:31 AM
yes i did tip it upside down and pull it i have tried the glow plug and it glows but just not the very end. thanks for trying to help
jnev 09-30-2006 11:25 AM
then it's a bad plug.
troll2000 09-30-2006 11:34 AM
okedokey but even if the glow plug is bad surely the pull starter shouldnt be stiff?
Brent07 09-30-2006 11:36 AM
How new is the truck?
troll2000 09-30-2006 11:47 AM
probably about 3 months old only had about 3/4 - 1 gallon through it
Steve455400 09-30-2006 12:22 PM
yea as I said get a new glow plug try that first cause if the end insn't lit then it's junk and it will cause your truck to flood over and over again so do that first.
troll2000 09-30-2006 12:22 PM
so will it work when i get a new glow plug or will i need something else as well?
Brent07 09-30-2006 12:53 PM
Sounds like it just needs a plug.
krazor 09-30-2006 02:14 PM
ive found if the t15 keeps flooding then un flood it and when you try to start it back up again back the glow plug off slightly and try to start it
when its running tightern it back up its never failed me yet
Elite_Tux487 09-30-2006 07:41 PM
Let it sit with the glow plug out for a while it should air dry out and it should be fine.
dannthenitroman 09-30-2006 08:50 PM
I dont think this snegine is flooded myself, ive seen the t15 break a few times, shattered cranks, and broken crank pins. theres no way its still hard to pull EVER with the glow plug out.
Dann
troll2000 10-01-2006 03:32 AM
oh i thought i will mention that if the glow plug is removed or loosened it is easy to pull. by the way thanks for all the replies:D
dannthenitroman 10-01-2006 04:11 AM
oh, so its prolly fine .
Dann
troll2000 10-01-2006 05:42 AM
I thought i would mention that i have just taken the engine apart to check for damage it all seems fine so i put it back together and it still wont start and is quite stiff too[:@] it also makes a sound a bit like metal hitting against metal when i pull on the pull starter if that helps
troll2000 10-01-2006 05:44 AM
oh and also seeing as i have taken the engine apart i dont think it is flooded so it must mean that it is something else but i dont know what
could it possibly be a problem with the pull starter?
troll2000 10-01-2006 07:01 AM
also before the glow plug igniter is put on it sounds ok if i pull on the pull starter. But when you put the glow plug igniter on thats when it goes all stiff and makes that funny sound.
troll2000 10-01-2006 09:28 AM
any ideas getting a bit bored lol[X(]
MetallicaJunkie 10-01-2006 09:43 AM
sorry i didn read through the whle pst, either you have a bad batch of fuel...... verify it by spotting a buddy of yurs a tank in his ride......... OR you might have the low or high end needles valves too rich, or a bad plug, .............. usually when u have a bad plug it wont stay on with out a glow plug igniter or has a rough idle...... if u dont have a designated RC CAR glow plug, u can always get one from one of your model airplane engines, and it will work fine
also make sure all the parts on the carb are the way they are supposed t be, tight, centered.....etc
troll2000 10-01-2006 10:07 AM
supposing the needles are set completely wrong surely i would at least be able to start it?
RCtruckRacer 10-01-2006 10:51 AM
Can you move the flywheel freely through the first part of the stroke? i.e. put the piston at BDC and you should easily be able to move it up and down between where the pinch starts and BDC. If so, you are fine and that is normal. My RB V12 had such a tight pinch through the first gallon that I had to keep a screwdriver around to unstick the piston from TDC when starting (I had to pry the flyweel with a screwdriver to unstick the piston). It took several hours to get it to start the first time. Some engines just have too much pinch to start with, but those engines usually last the longest as well.
