Nitro Rush Evo
1 Attachment(s)
Hey guys this will be my first nitro truck. I got the truck off of ebay it is in pretty rough condition but for the price i couldnt refuse, also it will make me a good winter project. I have a couple questions concerning this truck, are there certain parts that i should be worried about and stock up on ( I no it is discontinued) Also i have a Dynamite Mach .15 engine that i will put in her. Is this a better engine then the stock T-15? Also i would love to run it in the snow, what should i do to protect my servos? Also i was thinking of buying these tires which should help with the traction.
http://www2.towerhobbies.com/cgi-bin...?&I=LXDT99&P=7 Also how do you keep running temps up in the winter?Im guessing you insulate your engine some how (i have heard of a cotton sock being used). The engine is barely used and i got it cheap so i guess i could always use it as a back up if the one that comes with the truck is blown http://www.dynamiterc.com/Products/D...ProdID=DYN0880 Thanks for the help alex |
RE: Nitro Rush Evo
Just about anything is better then the T15. I suggest you get some middle gears for the transmission and some spur gears. To get temperatures up in real cold weather wrap the head in aluminum foil.
RE: Nitro Rush Evo
yeah any think is better than the t-15, the t-15 is a b**** to tune and doesn't hold a tune very well. Ive got one in my mt2 [&o] and do not like it, its been running fine now that the cold weather is hear but I'm trying to get hold of a o.s .18cv-rx for the summer time :D
RE: Nitro Rush Evo
What should i do about my servos? Wont water wreck the servos? Also how fast do you think this truck will go with the mach .15?
Thanks alex |
RE: Nitro Rush Evo
With the mach 15 and all that aluminum around 30 maybe 35 MPH if every thing is set up properly.
RE: Nitro Rush Evo
Do you guys no how much all of this alluminum would of cost im new to this also what parts do you see that are aluminum all i can see are the a arms and shock towers? Thanks alex
RE: Nitro Rush Evo
Looks like upgraded turnbuckles but the pic is not zoomed in enough to see all.
RE: Nitro Rush Evo
Hard to tell what all is aluminum but if it was mine I would be changing it back to the stock stuff for more then one reason. Been through the aluminum craze and I am over it, will never go there again.
RE: Nitro Rush Evo
with the servos, i tried something similar to the tower hobbies shrink wrap on my RC10gt and...i haven't tested it out yet but when winter comes ill test it. heres a link http://www2.towerhobbies.com/cgi-bin...&I=LXDZ18&P=ML
| All times are GMT -8. The time now is 12:53 PM. |
