RCU Forums
-   RC Nitro Stadium Trucks (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/)
-   -   problems with an MT2 (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/5267095-problems-mt2.html)
radchad84 01-15-2007 12:10 AM
ok heres the story
i got my new MT2 18ss
i built it and prepared it for break in
then i got impatient
i went about half way thru the break in
now i have millions of problems
its hard to start
over heats within a minute of idle
cant properly stay in idle
stalls within minutes of starting
and burns the components
is this happening becuz of my impatience or
cuz of a messed up tuning process im somewat unaware of?
wat can i do to save this engine
rapsucks_07 01-15-2007 12:22 AM
RE: problems with an MT2
ur screwed up big time man ur engines dead now
rapsucks_07 01-15-2007 12:24 AM
have u tried going back to factory settings on the engine or richening the lsn and the hsn
djheptic 01-15-2007 01:14 PM
ORIGINAL: radchad84
ok heres the story
its hard to start
dude in this hobby you need to be patient just a heads up.
to me it sounds like your engine is screwed. the breaking in of a nitro engine & any other 2/4stroke engine is the most most most important thing.
are you new to the hobby or do you know what your doing tuning wise?. if i was you i would read the engine manual and set everything back to factory and re-tune from there. remember you want plenty of blue smoke at full throttle/top end.
kuhndog599 01-15-2007 08:02 PM
hey i was patient with my mt2 and it still turned out like that. i guess both of us have bad luck. they wouldn't replace it either.
46u 01-15-2007 09:18 PM
1 Attachment(s)
I do not like the HPI 18SS and am so glade when I got my MT it came as a kit with out and engine or radio set up. Mine has been through many changes and has had the crap run out of it. Has been a great truck. If I where to get and HPI MT 18SS the first thing I would do is sell the engine on ebay and get and OS 18 CV-RX. As you can see mine has a little run time on it. Picture was taken when I was taking out my OS 15 CV-RX and putting my OS 18 TZ in.
boohoo 05-16-2007 03:09 PM
just got a mt 2 charged glow starter put on car put roto in and nothing for first few trys then it ran for 2 seconds and cut out havent touched settings for carb as they were right anything else i can do thanx for the help
46u 05-16-2007 04:30 PM
Is it used? You say the setting is correct but settings need to be changed all the time for weather conditions. Have you tried putting them back to factory settings and then retune as needed? Are you sure the glow plug is good and the igniter is working properly?
boohoo 05-17-2007 12:10 PM
its brand new just checked glow plug and think its knackered taking to model shop and see wat they say
boohoo 05-21-2007 02:39 PM
working just fine until i broke a c cup going to order some gpm stuff
46u 05-21-2007 03:45 PM
Just a heads up do not get the GPM junk and save your money for things that really help. If you just have to have heavy alloy HP robbing parts get something better then GPM!!!!!!! ;)
boohoo 05-22-2007 11:13 AM
thanks for that
