Shocks
Hey just wondering if theres anything i can add to my current shocks to give me better ground clearance or if u would recommend any new ones i could buy to improve it (to fit a Firestorm 10T)
RE: Shocks
try changing the shock oil...its probly the cheapest way...just put thicker oil in and that should help a lil bit
RE: Shocks
o.0 You could Try my quick-click shocks
really simple and uses your shocks all you need is 2 servo arms(single post) and 2 screws put the servo arm(geared end) on the stock mount spot and put the shock on the other end Tada go from low and soft to High and and med with a simple flip |
RE: Shocks
Try taking the spring off and stretching it a bit[&:]
RE: Shocks
1 Attachment(s)
a bit off topic as it doesnt raise the ground clearance !! but i put some fuel tube around the suspention shafts which makes the suspention bottom out ,before the car hits the floor . this stops my car's chassi etc .from hitting the ground off big jumps !
RE: Shocks
great idea lewis i will try it :)
RE: Shocks
doesnt the firestorm have different mounting spots
RE: Shocks
hmmm not sure what u mean ? explain
RE: Shocks
Also is it a good idea to buy some shock covers ?
RE: Shocks
ORIGINAL: Santacruz Also is it a good idea to buy some shock covers ? never hurts to have them it will keep the dirt off of the shaft |
| All times are GMT -8. The time now is 08:35 AM. |
