RCU Forums
-   RC Nitro Stadium Trucks (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/)
-   -   jato help (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/6684160-jato-help.html)
Corey02 11-28-2007 12:25 AM
jato help
HOW DO U SET YOUR JATO 3.3 BACK TO FACTORY SETTINGS
motorhead91 11-28-2007 07:57 AM
RE: jato help
call traxxas...i know the high speed needle is 4 turns out, but im not sure about the low speed
cool rc cars 11-28-2007 10:17 AM
RE: jato help
the low speed needle is hard to set as well as hard to get to. first clean the low speeed needle with air compresser or a toothpick. once that is clean you should be able to see a black ring on THE INSIDE of the whole component.( do not take apart the needle )the needle should be even with this small ring. for a better explanation go to traxxas.com and look at jato information
nothinbetr2do 11-28-2007 10:23 AM
RE: jato help
factory settings are hsn-4 turns out from closed, and lsn is screw head flush with the end of the slide(not the throttle arm)
motorhead91 11-28-2007 01:55 PM
RE: jato help
yep the low speed needle is a pain to get to with the ez start, im putting a pull start on it to make it easier to getto
Jim8ightT 11-28-2007 02:24 PM
RE: jato help
low speed needle is 1.75 turns from closed setting it flush is way too rich and is factorie settings. it took me a few days to fix it becasuse the low speed was set to high. just to let you know that it is a very rich setting i have my high speed 3 turns out and my low 1.6 it works for my needs and temp cold up hear....
Corey02 11-28-2007 10:12 PM
RE: jato help
thanx for all the help could i just take it down to my LHS and have them tune it or would that cost a arm and a leg.
thanx,
Corey
stinkypinky 12-09-2007 07:21 PM
RE: jato help
Nick2618 12-09-2007 07:24 PM
RE: jato help
you can but you will never learn how to tune the car your self that way....
