RCU Forums
-   RC Nitro Stadium Trucks (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/)
-   -   Engine help needed (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/6696575-engine-help-needed.html)
champyy 11-30-2007 06:38 PM
Engine help needed
Ok...first off..Im new to nitro..I bought two xxx-nt's from a guy..one was stock and it works fine..Other has an OS .12 CV engine using starter box...Well i got it to start a couple times but it would rev really high and then cut right back off...Now..I can't get it to do anything now..Is this thing dead?Does anyone know about how much it would cost to have it sent in to be fixed??Or should i look for new engine..Keep in mind i want to race with truck..but in rc pro series that i've been looking at.you can use 12or15 engines...
scottywilkes 11-30-2007 07:03 PM
RE: Engine help needed
sounds as if the idle screw is right open, or the high and low speed needles are lean as buggery.
Download a manual of of OS website and get the factory settings, set the idle so the gap in the carb is only 1 to 1.5mm, and u shoyld be good to go, once u have the factory, u can start tuning the motor till it runs good
scottywilkes 11-30-2007 07:05 PM
oh yeah and replace both the motors glow plugs, OS8s work great in OS motors, and it should work great in the mach 15 as well.
And replace all fuel tubing
The best thing to do would be to totally dissasemble both motors and clean them and inspect, seeing there second hand they might be gummed up inside
champyy 11-30-2007 07:29 PM
Ok...i'll try that...I had to buy glow plug for os engine and thats what i have in it..the os 8 plug...
champyy 11-30-2007 10:45 PM
Ok...i tried setting back to factory but still nothing..I started to take engine off truck but screws stripped on bottom holding blocks so i'm gonna have to get some extractors...I'm also watching a os 12 cv-r on ebay...
scottywilkes 11-30-2007 11:29 PM
do u have a dremel? If so use a cutting bit and cut a groove into the bolts, that way u can use a flat bladed screw driver to undo the bolts, worked for me countless times
avg_joe 12-01-2007 11:24 AM
Also, on engine mount screws, you could grind off just the head of the screw. Then when you take the engine off, it leaves a stud sticking up. You can easily grab this with a pliers to remove it. I would try cutting grooves first, though. Like scottywilkes suggested.
champyy 12-14-2007 01:04 PM
alright..i'm able to post again..My comp was down for a week or so..But i got those stripped screws out and put in os 12 cv-r i got off ebay..found that the prob that i was having was with the fuel hoes tho..So the engine that i took off may work...not sure(os 12 cr-x..Still need to get motor tuned in tho..
