Starterbox Question
Can I use a starter box and leave the pullstart on or is it a MUST that the pullstart is removed and a backplate installed ?
RE: Starterbox Question
you can use a starter box with a pull start on.
Will it result in any damage at all or ?
If they can be left on whats the purpose for a backplate ? |
no you will be fine you can even take JUST the pull start off and run it like that. A back plate is like 15 bucks just get one if you are going to a starter box..
ORIGINAL: Toki no you will be fine you can even take JUST the pull start off and run it like that. A back plate is like 15 bucks just get one if you are going to a starter box.. I am going to a starter box, that's what I said. So I need a backplate then or ? |
it will not hurt your motor to leave the pull start on.
If you are going to get a starter box then yes get a back plate. |
it will be to your advantage because it will allow the motor to spin with less resistance and crank out a few more rpm's
| All times are GMT -8. The time now is 12:38 PM. |
