RCU Forums
-   RC Nitro Stadium Trucks (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/)
-   -   broken mt2? (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/7654603-broken-mt2.html)
ma-drummer25 06-24-2008 07:06 AM
broken mt2?
Hi there I have a HPI MT2 nitro car and i cant seem to get it started. Ive checked all the usual things you would check and i was just wondering is there anything else that i could look to see if it is working properly?
Thanks.
snipermaster 06-24-2008 10:50 AM
RE: broken mt2?
this is from the manual:
Engine does not start
Possible Problem
Solution
out of fuel
Refill fuel tank
Contaminated fuel
Replace fuel
Glow plug is bad
Replace glow plug
No fuel flow
Check fuel lines for cracks, leaks, and holes. Replace fuel line if necessary.
Engine flooded
Remove glow plug and discharge fuel
Engine has overheated
Allow engine to cool, richen the fuel mixture and restart
Throttle valve isn't adjusted properly
Set idle to neutral and reset linkages according to radio and model manufacturer's specifications
Air cleaner is blocked
Check air filter. Clean or replace of necessary.
ma-drummer25 06-24-2008 10:59 AM
RE: broken mt2?
thanks. I hadnt thought to look in the manual ill have to check and see if there is any of those problems. Thanks again.
yakfish 06-24-2008 11:21 AM
RE: broken mt2?
yeah the manual can tell you all sorts of thing about your cars!!lol!:D
bionictony 06-25-2008 01:43 PM
RE: broken mt2?
when you put fuel into the tank you have to "pump" it into the engine carburetor. its in the manual on how to do it if you have a roto start or pullstart
ma-drummer25 06-25-2008 03:53 PM
RE: broken mt2?
yeah i always do that. I got it going today anyway. thanks for your help
snipermaster 06-25-2008 04:45 PM
RE: broken mt2?
ma-drummer25- great to hear you got it running. now go out an run it like theres no tomorrow.
ma-drummer25 06-25-2008 04:49 PM
RE: broken mt2?
cheers. But ive got another problem now it just revs load and doesnt move anywhere but i think its got somthing to do with the gearing.
snipermaster 06-25-2008 05:02 PM
RE: broken mt2?
on that one i would check your slipper clutch, and see if it needs to be tightened.
ma-drummer25 06-26-2008 04:45 AM
RE: broken mt2?
thats exactly what i was thinking im gonna check that later.
