RCU Forums
-   RC Nitro Stadium Trucks (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/)
-   -   Replacing EZ-Start (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/7823046-replacing-ez-start.html)
Jozachar 08-08-2008 07:27 AM
Replacing EZ-Start
I am going to replace the TRX 3.3 EZ-start with a pull starter and i need to know if this is it? Here is the [link=http://www.rcplanet.com/Traxxas_Recoil_Starter_p/tra5170.htm]Link[/link]. And also, do you have to take out the engine to put this in or can you leave it in the car for installation?
Jozachar 08-08-2008 07:54 AM
RE: Replacing EZ-Start
Can someone plz help me. I'm new to rc cars and nitro
Jozachar 08-08-2008 08:53 AM
will someone help me!
DaveG55 08-08-2008 09:42 AM
Yes, that's it. Yes, that should be all you need. Yes, the engine will have to be removed to switch to a pull start.
Hope you know how to tune, otherwise you can expect some serious blisters between your fingers.
Be sure to carefully adjust the gear mesh between the clutch bell and spur gear when you reinstall the engine.
http://www.traxxas.com/support/kb_se...highlight=mesh
Good Luck
nitrosport963 08-08-2008 11:49 AM
no u don't need to take the engine out u just unscrew the screw that holds on the exhaust in the front and twist the hole exhaust straight up and down an u might need to tack the back left tire off if u cant get the screw
nitrosport963 08-08-2008 11:51 AM
ORIGINAL: nitrosport963
oh wait is it a 1 piece exaust
Jozachar 08-08-2008 12:59 PM
It is the stock exhaust
Jozachar 08-08-2008 01:03 PM
ORIGINAL: DaveG55
Good Luck
What do you mean by tuning? Wouldnt it be the same as with the EZ start?
nitrosport963 08-08-2008 05:08 PM
if it is not tuned right it wont start
nitrosport963 08-08-2008 07:20 PM
and srry u will have to pull the engine
Mr.Positive 08-09-2008 01:09 AM
Have fun with all the nics and blisters your gonna get. Pull starts imo are only good if you no what you are doing tuning wise. If you just want the pull start for the loss of weight just get a bump box instead much easier to use imo.
