slayer problem!!! need help!!!!
well i was running my 3.3 slayer and it shut off the engine spins new spark plug but no start. it also pulls away when im starting it. like the clutch is stock or something. this is my firs rc car so dont know a lot about them. this is frustraiting today sunday and no toy......
RE: slayer problem!!! need help!!!!
You probably broke a clutch spring [:-]
is that hard to change?? where can i get a R&R diagram??
Traxxas has a web site with all the manuals and exploded views.................all you have to do is pull the engine and remove the clutch bell [8D]
hey thaks for that..... but why do they break??
You got a bad one. Usually the clutches need to be worn pretty hard to get the spring broken. You should be okay once the replacement is put on.
i had my slayer for two days before i busted my clutch shoes, ive replaced them with mip clutch shoes. when it broke it was the actual shoe, my springs were fine. something i hadnt seen before. but the mip seem to be holding up fine. my new clutch shoes have a second mounting hole, for tuning your clutch.
ok i took it apart today and i dont find were this springs goes no clue at all!!!! took out the engine the clutch and the flywheel and no spring pliss were can i find this spring!!! te clutches looks fine!!
ok find it te spring and the clutch was broken thnks evryone for the helpfirst time using this forum and great response
Well at least you found that the spring and shoes were broken, was going to let you know thats what happened to mine also. Mine also had the same problem for it not starting. What it turned out to be was the blue wire for the glow plug was bad so I just started using a glow ignitor untill I got around to replacing the wire. Hope this helps you.
| All times are GMT -8. The time now is 10:31 PM. |
