Glue for Lexan bodies
Hello
Iam about to start on a ABC hobby body. But i need to glue on Spoiler and light buckets. Can anyone advise me on what type of glue to use?
RE: Glue for Lexan bodies
http://www.hobbyking.com/hobbyking/s...)_<b>Medium</b>
http://www.hobbyking.com/hobbyking/s...>Super_Thin</b>
The one is medium visocity and the other super thin(I used the medium)
The medium is better for your use
Hell I used E 6000 on my light buckets and side mirrors and that works perfect it has some qualties of hot glue minus the hot part its really rubbery but once stuck it sticks good but its easily removed to if you want
ORIGINAL: dalla1982
Hello
Hello
ORIGINAL: AL3xGR
A CA glue would be ok I thing.(Cyanoacrylate)
The best CA is at Hobbyking.This with the medium viscosity.
For RCbodies, use ShoeGoo or Goop, itcan be found in most major retailers in the hardware/sporting goods/crafts/shoesdepartment.
It'll bond about anything to anything (including paint or crome), is flexible, doesn't fog, is transparent, is easy to use, and can be removed it you want to change spoilers or something.
