racing stripes on a stadiam truck body
WA,
i want to do racing stripes for my stadiam truck i tried tape but that was a little hard. do u think i should use paper and lay it along it or stick with the tape
My Feedback: (32)
RE: racing stripes on a stadiam truck body
use paint mask from your lhs. i use it all the time and works great. find the mask that is labeled cut to design. you will like this ,
My Feedback: (-1)
TX
i just did a skyline with stripes on the hood i used blue painters tape it works the best for me to make the lines strait and even i used a ruler and my line came out great.
good luck.
good luck.
PA
I don't know if you can see my stripes on my NMT clearly enough, but I used masking tape for them from walmart. You heat it up a little to make it sticky and stretch a little. Use the end of a pen cap, you know that little stick to make sure it goes into the grooves otherwise you get funny little bleed marks. Otherwise just take your time and space them out properly.
PA
Here are a couple skyline stripes that I've done. The first one is a 300 mm body. I still have that body. THe other one is a regular 200 mm skyline body that I sold already.
Just watch out for the fold and cracks
