Sticker Paper
MD
Sticker Paper
Ok, this has been asked before and the search didnt help much. I need to find sticker paper, the kind you use for decals on the body shells. I want to print out a picture and put it on my truck. Does anyone know where to get this paper? It needs to be clear just like decals are.
Thank you.
Thank you.
RE: Sticker Paper
Clear would be good so you can stick it on the inside. I've been thinking about some artist tack spray adhesive, on photo paper too, I think it would make computer ink run/bleed though. Maybe I'll try it and let you know.
RE: Sticker Paper
try getting some water slide inkjet decal paper, and some acrylic spray. the spray seals in the design on the paper so that it does not run. You can get it in clear and white, if you use the clear then you might want to back the design with a lighter colour. I have used the clear version on this shell and have put it on the inside of the shell.
RE: Sticker Paper
hi all im after some sticker paper aswell for my buggy so i can create some designs in photoshop but carnt find none, is it a4 ? and basically just clear
thanks HD
thanks HD
RE: Sticker Paper
i want 2 do custom stickers too, but i can't find any acrylic clear coat![]
anybody got a URL or store name (tried home depot, lowes, wal-mart,...)
can't find it![:@]
can i just put clear sheet of water slide paper on top of the decals i made?
can't find it![:@]
TX
RE: Sticker Paper
We have a Hobby Town close and they have the clear. I just looked at it this last weekend. XXX has what you want as well. Sorry I do not have the web adress at work. Also try Tower Hobbies they sell XXX Main Racing.
OK
RE: Sticker Paper
Testors.com may help you find the ink sealer. They have a decal program that comes with a starter kit (couple sheets of water slide paper, the sticker sealer, and the CD with the program). I have to admit that the graphics options that are included in the program are lame, but it is a start.
TX
RE: Sticker Paper
You didn't look hard enough [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXNH95&P=ML]Decal Paper[/link]. Tower has almost everything. Hee hee..............
My Feedback: (9)
GA
RE: Sticker Paper
i got some at hobby lobby i think it was about 5 or 6 bucks for like 10 sheets. dont quote me on that but i do remember it was not too expensive. much cheaper then buying decals!
ND
RE: Sticker Paper
I know that you can buy big sheets at a silk screen place. It is the vinyl stuff ans It is pretty cheap because they buy it in bulk and usually have rolls of left-over pieces. You could probably find a silk screen place if you looked in the phone book.
RE: Sticker Paper
So, I've actually tried the Testors paper, on my fairly new HP OfficeJet (it's an inkjet printer). I also used the spray that Testor makes, to protect the printed side. I've only tried this twice, but both times I had the same problems:
1) When applying the protective spray, it's really easy to get blank ink to "float", and it ends up looking purple or even red. Putting on super thin layers of the spray helps, but since this is a can, it's not all that accurate. Several times I've got large "drops" of the spray on the paper, making a serious bleed on the printout.
2) When transfering the stickers to the car, I can't seem to avoid getting "cracks" on the printed areas. In particular black areas are very sensitive to cracking, and it's definitely noticeable.
For 1) above, I guess it's a matter of patience, and slowly apply layer after layer of thin spray (one thin layer is not enough to protect it from getting ruined in the water). But for 2), any suggestions what I should do? More layers of protective spray?
-- Leif
-- Leif
