Carbon Fiber?
TX
RE: Carbon Fiber?
On real cars carbon fiber is used to make the car lighter. It also keeps the car cooler because its not metal and metal conducts heat more than carbon fiber. So when its hot outside your engine tends to get hotter because its normally always going to be hot with the sun adding on more heat. If you have a carbon fiber body that covers the "engine head" your engine just wouldn't be as hot as it normally would. Well I guess it would be a better idea to make the engine head carbon fiber than the body. I might try that one day just to see what it would do it was just something that pop into my head.
RE: Carbon Fiber?
ORIGINAL: flash07
I think you will find that the metal from the body will also help to take heat away from the engine, so if anything a carbon fiber body will reduce the heat transfer thus making the engine hotter.
CA
RE: Carbon Fiber?
ORIGINAL: flash07
CA
RE: Carbon Fiber?
Here is a Tutorial i wrote on CARBON FIBRE. Enjoy![link=http://www.cfxpaintworks.com/modules.php?name=Forums&file=viewtopic&t=10]Shedded Carbon Fibre[/link]
