ok i picked up an air brush yesterdy
CA
so i picked itout it is cheap but works great well my question is the paint i got takes hors to dry is it ok if i put a nother layer on it why it is still drying? can i putt in the oven and put it on the hot light thing or lowest temp?
Thanx,
Andrew
Thanx,
Andrew
you should always paint each coat with 5-10 min intervals, spraying the next coat on to a tacky previous coat helps the coats to bond better with each other, just make sure the coats are not too heavy.
Tim
Tim
