Engine Vents
Engine Vents
Is it required to cut part of the windows out in order to cool the nitro engine???
All your help is app. btw i run a hpi .15fe with a two speed trannie tops out around 55 mph thanks Zack
Engine Vents
Yes it is unless you want to overheat you engine and ruin it. You only need a hole about 1-1/4 inch dia. in the windshield directly in front of the motor and then maybe a little in the side window to make it easier to refuel when it is still running
Engine Vents
I've gotten kinda creative on some of my bodies and cut out the grill's and put a piece of screen to make it look like a speed grill. Looks kinds cool and I haven't had any overheating problems.
