How to paint checkered flag?
Is there an easy way using tape to mask out a flowing checkered flag. I kind of started cutting some tape with the ole exacto but it's way to hard. Any help or links would be great.
NV
You must cut your design out on a flat surface and put some kind of transfer tape over it. Lift the design off your cutting surface and apply it to the body. I use Smartape for this (both the masking and transfer tape). However I usually liquid mask checker patterns because they are easy to cut out. Stan www.1stplacerace.com
