How can i paint this? Painting tomorrow please help!
I have a revo platinum body that im painting daytona yellow with black pin stripes. How would i do this with masking tape and rattle cans?
Thanks a bunch! Please dont skimp on any details as this is my first body!
Thanks!
Thanks!
OR
if you have to ask how to do pinstripes and for every single step in detail you probably arent ready to paint anything other than single color. Why dont you just do it a single color and buy the pinstriping seperate? that way if you mess up the pinstriping you can do it over.
if you are insistent on trying to do a 2 color on what is your first car body you have painted there is tutorials available - your already on the internet - the worlds largest repository of information.
I didnt really want every single step [:'(] Im guessing i mask my whole body but leave my stripes and paint black, then remove all tape and then paint the whole body yellow?
ORIGINAL: Yaksaddle
Why bash someone for asking a question? The guy just wants to make sure he does it right the first time.
thanks dragon, would i have to mask the entire car just to do the stripes? And saddle, i dont get whats with the bashing, i asked a simple question, you were a noob at painting too once you know
I would mask the whole body. There are several things you can mask the body with, you can use blue painters masking tape, regular masking tape or liquid mask. The liquid mask is applied to the body using a paint brush, but it you are wanting to paint tomorrow you would be better off with the masking tape. There are several keys to painting and having it turn out nice. Make sure the paints (polycarbounate) are made for the lexan bodies.
1. Wash the body
2. Dry it
3. Aplly work masking tape
4. Make sure all the edges on the tape are tight so paint won't bleed under it.
5. Paint in light coats, letting them dry between sprays
6. Remove masking tape slowly after the paint is dry
7, Then spray the main color in light coats
8. Once you get it painted you will want to back it in white.
9. Take your time and be patient when your painting.
1. Wash the body
2. Dry it
OR
It wasn't meant as a bash in any way
I apologize if my original post came off as harsh.
it was not intended to be.
I second everything he said above - make sure the masking tape is tight then tape it even tighter - use the edge of yoru drivers license, or credit card to really get it in tight spaces and curves etc. I use some rounded edge toothpicks for the fine work. Nothing is worse than having to hide a gorgeous paint job under stickers because of bleed.
Patience, light coats, proper drying time, proper amount of space, you picked 2 great colors as both will make the other color pop - sounds like you are doing a kind of Bumblebee look.
be careful for drips watch the tip of the can for buildup, go slow, be patient especially with how cold it is right now your dry time will be longer than if it was warmer.
Go thru the whole process mentally, make sure you have everything you need at yoru disposal while you are painting.
You will learn something new every single time you paint if you are prepared and patient and go slowly.
Best of luck!
Best of luck!
OR
Just a thought are you doing black pin stripes along the side of the body or more like racing stripes along the vertical line of the body??
Pinstriping will be easier as you will be able to find 2 end points on the front fender and rear fender to make it level line.
if its racing stripes I use one of those laser levels to project a straight line or at least help me get as "close" as possible.
I find the thinner the pinstripping the easier it is for me to visually see bleed so I usually do the racing stripes thicker.
Thanks saddle, your first post just came off the wrong way. Im doing it along the hood, roof and trunk. I never thought of it but it is like bumblebee from transformers
That laser sounds like a great idea but i do not have access to such a thing.
![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
CT
You will learn alot on the first body,just have fun. show us a pic hen your done.
Like above,
dark color first then lighter colors.
Like above,
Im finished. It bled in some places, i placed the decals and it looks better, it looks pretty good i think (for a first body).
![](http://i286.photobucket.com/albums/ll102/jnelson2008/100_1237.jpg)
They were very thin coats. I did like 5 thin coats, it was my masking job that messed it up.
Dragon here is a top picture and the side and rear. Im guessing you want to see them to see how bad i did. I think im going to try liquid mask next time... My stripe is uneven and it bled a bit, you can see above the bumper to the left, the bumper covers most of it up.
![](http://i286.photobucket.com/albums/ll102/jnelson2008/100_1240.jpg)
![](http://i286.photobucket.com/albums/ll102/jnelson2008/100_1239.jpg)
![](http://i286.photobucket.com/albums/ll102/jnelson2008/100_1238.jpg)
Im 14 and this is my first body (other than a heli body i sprayed all blue) so give me a break![Smile](https://www.rcuniverse.com/forum/images/smilies/smile.gif)
My revo is awaiting a heart transplant, she will be getting a picco red dot into her [>:]
A laser level would be such a good idea but i do not have access to one. Im thinking i should have just painted it all yellow. Someone should give me ideas for my next body as i can get these for $20 a pop. My window maskes worked great, no bleeding at all there. Im thinking of doing a one tone for my next body and just putting the revo decals onto it. What colour should i paint it? Orange?
ORIGINAL: t9dragon
Looks great. I have been painting bodies for about 15 years now and I still have bleed marks occasionally.
![EEK!](https://www.rcuniverse.com/forum/images/smilies/eek.gif)
CT
No worries...rattle can paint loves to creep under tape....you didnt do anything wrong realy.
Keep the can far from the body so it is ALMOST dry when it hits the body....The mask does work better.
If you want to play with colors try some pearl colors or "flip flops" ....very easy and they dance nice in the sunlight.
Heres a picture of pearl black and it flops to teal/orange/and purple....simple paint cans.
![](http://i262.photobucket.com/albums/ii111/victory-rc/bajass001.jpg)
Ohhh! I seen someones revo that had the nicest pearl colour ever! It looked good. Thats what im doing next.
OR
did you mask the car the day of painting or the night before? I find that if I mask the night before the tape lifts all over the place and leads to bleed heavily, I just picked up like 4 touring car bodies I need to paint, I had a few ideas pop up while watching this thread for ideas - I will try and post them later - I posted the last body I did for the wife, pink and white Acura came out reallly nice - its a shelf queen though, she doesnt want to put it on the track and mess it up....
IN
ORIGINAL: quadracer111
As for my first shell it had bleeds and what not everywhere, and now it really doesn't have much paint left on it, but when I went to do my 2nd shell things were a night and day differnce. And now after about 2.5 years later I am at a really high level with my painting.
So what I would rather see you do is do another stripe paint job, and apply what you learned form your first body, and I bet you will get better results. Also right now worry about getting clean paint lines that are free of bleeds, then you can worry about getting nice stright and smooth cut/masking lines.
well i think its pretty good !!
considering yellow and Black are some times for many kinda hard to work with be cause of the high contrast in color....
looks "Clean" simple and nice....
for different things there are so many ways to go....i do "Custom Automotive Paint" and i never get over some of the different things even we'll do....
almost endless?....
but ask your self what colors are you likeing this week? or to just try? maybe a Light color with higher contrasting stripes?
maybe just a single color again but with a pearl color, those always look cool.....
here's one? maybe an example for something?
dont pay attention to the speckels or the "Purple" airbrushed painted just under the Burgandy stripe....
but the overall idea...
these are kinda fun and simple....just get some 1/8 inch tape....no need to try and cut a line consistantly that wide...no need to make it hared than it is![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
just lay it along the side, then get some 1 inch or 2 inch tape which ever you feel comfortaple with![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
lay it "lenght wise" you'll be covering the pinstripe but thats ok....then once that is done should be kinda smooth, then take your X-acto knife
and "Lightly" score alone the top of the pinstripe yep, right on the middle..,it will be slightly raised because you covered it,and when held a littl to the light you can see it
i know it will seem hard but really not to hard but try not to cut to much into the pinstripe....
(I'll even post a short video if this can help everyone??)
then just peel away the tape that "overlapped" the pin stripe......and paint away for the top....
then paint the bottom, then peel away the pinstripe....paint all done.....![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
i hope this can maybe give a few ideas....![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
lets see your next project !!...sounds like it could be Interesting....![Smile](https://www.rcuniverse.com/forum/images/smilies/smile.gif)
Oh, and you can do the little speckels with out an airbrush if this is something you'd like to try?
get an Old tooth brush, some latex gloves or something similar so ya dont get pait all over your hands, and the trusty "Rattle Can" paint....
so, just spray the tooth brush "Heavy" with paint...and run your finger over it...like when your done brushing the teeh and your drying it off....
practice on some old cardboard to get a feel for it...has a cool effect ....![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
![](http://img.photobucket.com/albums/v495/1blade1/Luna684.jpg)
almost endless?....
