masking
i am having a hard time grasping the concept of masking, i get the idea to keep paint from getting to one spot, like window masks and some patters, i wanna do a flag on a viper body for my T4 or my tc, should look sweet. what is liquid mask?, how should i do basic masking?
RE: masking
I don't know but am very interested myself.
RE: masking
Liquid masking film (LMF) is a thick liquid that you paint on and allow to dry. You then use an x-acto knife and cut patterns in it and it will peel away from the body. Most people agree that Bob Dively LMF is the best out there. It dries clear so you can use a marker to draw on the outside of the body then cut on the inside for your patterns. Use several coats. Very easy to use and provides consistently good results.
RE: masking
Try Bob Dively Liquid masking film. You can see how to use it by going to aero-accessories.com and click on the applications button below the product.:D
RE: masking
hmm, ok, since then i did a fade job on a hummer though, but i will still look thanks
RE: masking
what is the best way to apply liquid mask.. paint it on with a brush or water it down a bit and spray it on with a spray bottle?? I don't have a compressor or airbrush. thx
RE: masking
brush i think
RE: masking
You definitly want to use a brush for liquid mask. You want to do about 4-5 good thick coats of it on the body. Let each coat sit for about 20 minutes + and then let the final product sit overnight before you start marking it up.
Also I'd recomend drawing directly on the liquid mask that way when you cut it out you are getting rid of the marker as well. |
