Go Back  RCU Forums > RC Airplanes > Pattern Universe - RC Pattern Flying > RC Pattern Flying
 Futaba 12FG replacement TX battery pack >
Old 07-15-2011 | 07:02 PM
My Feedback: (15)
Default Futaba 12FG replacement TX battery pack
Hey Guy's
Need some help, I'm looking to replace the NI-MH battery pack for the 12FG transmitter, with a LI-PO pack. Has anyone out there replaced the pack before.
Also I'm trying to set the Dual Rate switch, it a 3 position switch for dual rate, but I can only set 2 of the 3, is a condiction needed to set the 3 position.
Old 07-15-2011 | 07:21 PM
woodie's Avatar
Default RE: Futaba 12FG replacement TX battery pack
Jarvis, here is the info from the Futaba RC support FAQs for the 12FG and triple rates.
Radio System FAQ
How do I setup Triple Rates on my 12FG?
To set up dual rates, go to Dual Rate screen in the Model menu. Go to Function in the center of the page and select the control surface you want to set up. Scroll to the Status and select On of Off.
Next scroll over to the right hand side of the page and choose the switch you want the rates assigned to. You will want to go into the On/Off selection screen and assign the position you want your lower rate set to.
Now back out to the Model menu screen again and go into the AFR screen. With the switch you selected in the UP position, your AFR will most likely be set to 100%. If you want or need it set lower, do so now. Next flip the switch that you assigned your Dual Rate to and reset the rates to the amount you want your lower rate set to.
Now you have your AFR's position as full throw, bottom is low throw or dual rates on that control surface.
Then go back to the Dual Rate menu and select D/R 2 and activate it and simply set this third rate the same as you did above.
By following this for your other surfaces, Ailerons, Elevators and Rudder, you can have triple rates all on one Condition.
Here is a link to all the FAQs for the 12FG.
http://futabarc.com/faq/faq-12fg.html
Woodie
Team Acme LG
Team Blenderm
Old 07-15-2011 | 10:28 PM
woodie's Avatar
Jarvis, here is a link to a search for 12FG and Lipo replacement packs. Looks like several have done it.
Woodie
http://search.rcuniverse.com/search....+&i2=12fg+lipo
Old 07-15-2011 | 10:33 PM
My Feedback: (15)
Thanks, alot Don
Old 07-16-2011 | 01:36 AM
viper2003's Avatar
i bought this for my 12 FG.
http://cgi.ebay.es/ws/eBayISAPI.dll?...EOIBSA:ES:1123
7 hours of autonomy. cool, cheap, beatiful. what did you expect?
Old 07-16-2011 | 02:40 AM
vquick's Avatar
My Feedback: (71)
Im using in mine this one I been ussing lipo in this radio for about year and half no problem at all
http://www.2dogrc.com/product/dualsk...i-poly-battery
