View Poll Results: A poll
Voters: 103. You may not vote on this poll
How weight affects YOUR participation at NATS
#126
My Feedback: (17)
CT
RE: How weight affects YOUR participation at NATS
Can you imagine what would happen if they got rid of all the "restrictive" rules in 'Formula Ford'? Let's see... uh, Formula 1? Isn't that more expensive?
#127
My Feedback: (50)
ORIGINAL: jrpav1
Can you imagine what would happen if they got rid of all the ''restrictive'' rules in 'Formula Ford'? Let's see... uh, Formula 1? Isn't that more expensive?
#129
My Feedback: (50)
ORIGINAL: jrpav1
Minimum (400 Kgs). I know where you're going with this but please, oh please don't say it here! LOL
John Pavlick
John Pavlick
#130
NC
ORIGINAL: Ryan Smith
The same way the rule requires that you be under two meters.
Honestly, this is the one major rule that has not changed since the inception of pattern. Displacement was increased, and size was increased. I'm not sure about sound, but I would guess it's been around for about the same amount of time as the weight rule. Why has this single rule got a bug up so many people's butts? I've been doing some more thinking about the weight rule elimination and what it could possibly bring to the table. I don't think Bob was very far off with his prediction of an AW 50cc Ultimate being a legal airplane, at least for a first generation. Even setup for gas, those are not cheap. Electric would be even worse.
rix, it's taken me a while to figure out who you are. I'm almost positive that we never met, as I started flying pattern in 2005. What did your airplanes typically weigh back when you were flying pattern before? What sort of equipment were you running back in those days? Has it been since you started dabbling back into it that you've been having weight problems? Did you by chance take weights of your airframe components before you started building to see where they measured up?
Maybe you mis-understand me. I can make weight with what I have and I really like what I have. But after weighing my stuff (all good stuff) with the two different brands of batteries that I have, I started asking myself, why did I just need to purchase $600 worth as opposed to $300 worth? The $300 gets me there performance wise even for Masters. Then I started looking at 2013 when I plan to fly Masters again and with the additional costs to do that with literally no flight performance benefit and I kept asking myself the question, why? Its not a personal taste thing, or that I need a turn-key solution nor am I going to be nipping at anyone's ankles. The Vanquish was not available options back in the day, and now they are and I simply started looking at the big picture and why a rule requires me to either spend money and or become a lab rat trying to trim weight by scrapping out heavy wing fillets with a dental tool. I am fine with any rule as long as its purpose and objective are of benefit and not unreasonably burdensome. Would some here at least agree that it would be reasonable to raise it slightly for all AMA classes (Masters Included) and not eliminate it altogether? I have given several good reasons in various posts as to why that might be of benefit. Again, I can make weight currently, and I will make weight for Masters including local contests as I do honor the rulebook, but for the life of me, I cannot figure out why some cling to it like its the Holy-Grail.
#131
My Feedback: (25)
Rules is rules, Rick.
I don't have the why, I just follow them because I love pattern flying. I love pattern airlpanes, and I love the way that they fly. They are built to conform to these rules, so I guess that's why I don't have a problem with it. I wish I did know that way when the discussion comes up again in six months, I can have an answer. All I can do is point out my arguments of why it should stay.
#132
ORIGINAL: nonstoprc
50cc gas for pattern? Even with a soft mount, I imagine that the vibrations will be strong enough that you need to beef up the airframe, linkages etc. also do not forget the heavy big prop. Doubt such a combo could meet the weight rule.
Did nothing extra to reinforce the Extra. The prop was a Mezjlik 20x12 3 blader. Guess what....this prop is lighter than a 19x11 apc that the guys are running on their YS170's
I weighed all of the components of the powerplant including the soft mount and stand offs. Weight was on par with electric set-ups except I lightened my DLE by 4 1/2 ounces. So all up with stock stuff, this set-up is around 5 ounces heavier than an E-set-up.
Now, you tell me: if guys can get electric models RTF at 10 1/2 #, why can't we get a 50cc class engine in a pattern plane and still make weight? BTW-the lightest stock 55cc engine is the BME58 Xtreme. Beautiful engine but the carb is ill located for pattern. The least expensive to machine and butcher is the DLE. So it was worth the investment to me to find out if this was doable
#133
If you have someone that believes that, hold on to them- I've got a bridge I've been trying to sell for quite some time now.
But some real options for 50cc motors are DA 50R for $549.99, DLE 55 for $369.99, OS GT55 for $649.99 or BME 50 for $514.00.
No $250.00 option here. And you'll need two batteries, instead of one pesky 900mAh one.
ORIGINAL: bjr_93tz
Hmmmm, piped OS 55cc petrol two-stroke single OR all the top IC pilots using 60cc YS flat twin, supercharged, nitro burning four-strokes???
OK maybe not at local club level but then again I certainly wouldn't pull my DZ170cdi and replace it with a cheaper OS 1.60, the same as I didn't pull the Hanno and replace it with a OS .91 when the capacity limit was lifted. The currrent crop of 50+cc gas engines offer excellent value and performance, of that I won't argue, but for pattern work they just aren't the whole package....
It'd be like putting a NASCAR engine into an F1 car, it'd work fine, be much cheaper to run and be a hoot to drive on a track day BUT ??
#134
NC
#135
My Feedback: (90)
ORIGINAL: MTK
If you ever saw how lightly built an 78'' EF Extra is built, you will realize that the piped 50cc gas engine on a pattern plane is NOT A PIPE DREAM. By Pattern standard, the EF Extra is a bit heavy out of the box. And mine, equipped with a DLE55, DA RTC header (stainless unit) and the ESComposites G55 pipe, weighed in at 12 1/2#. That's heavier than rules allow but not pachyderm heavy. There is weight to be saved on the header (the stailess unit weighs 5 1/2 ounces) and a bunch of savings on the model itself. Example, each wing panel weighed 20 ounces, the stB 12 ozs and the canopy weighed 10. Kept the stock 7/8'' carbon wing tube and it was plenty strong enuff
ORIGINAL: nonstoprc
I am not saying it is not feasible, it certainly requires some pioneering work and creative thinking. I used to run ZDZ40 FAI on a gas setup, the power is OK but the plane was heavy and flew no way better than e-powered planes.
#136
ORIGINAL: nonstoprc
Even the DLE can be made lighter, there is still more weight to trim on the whole. The weight rule is a reality check.
I've seen the very best electric set-ups flown by the very best in the country. I'm going on record as saying that this DLE set-up puts out more useful output with similar brakes as the best E. Noise is on par with YS170 4 strokes....Believe it or not!
Point is there is a heck of a lot that one can do with a little out of the box thinking. But enuff teaching unwilling pupils. On to better things
#138
NY
ORIGINAL: nonstoprc
Well, you own us a proof on RCU and I hope you are right!
Matt's cards are always on the table... the Good, the Bad and the Ugly.
#139
My Feedback: (58)
The rules are there to create a limiting construct for us to work within; remove a limitation and it will be exploited and costs will rise. Nature abhors a vacuum; give someone who can think creatively and has the money to spend the leeway and you will see innovation. However it will unfortunately be more than likely to cause the bar to raise and not lower. Power limitation was removed and we are still within the 2M box but the planes have certainly evolved and costs of said planes have gone up.
IF and I mean IF someone were to think this through and remove the weight limit then another limit would need to replace it. It could be a power output cap or perhaps a total aircraft volume or an airframe cost cap if this is really about controlling costs. Make a proposal that no airplane flown in an AMA Pattern class can cost more than $1000 for the airframe RTF less radio and power plant. With that you will have certainly controlled costs and the ARF manufacturers can crank out heavier planes and those with deep pockets can buy as many of them as they want and fly only the lightest while the the rest of us plebeians will fly a slightly heavier plane and the rules will now control costs.
As for Matt, he is one of the most impressive thinkers I have EVER met (and I know more than a few people with paperwork to prove they are geniuses).
I'll go back to lurking and working on work stuff again (If anyone has a position open for a CIO or an IT Director that would allow a good amount of flying time please don't hesitate to call me).
#140
My Feedback: (90)
Was not able to fly because of the cold front coming last weekend. So I did some weight shaving work on my Passport. Remember it is 114gram over the 5000g limit. Still within the allowance for my class but making it lighter is on my mind.
The work done.
1. Combined the battery wires for both pairs of elevator and rudder (split rudder) servos by cutting and soldering wires. Heavy-duty wires are used for +/-. The total saving is 0.6oz. A side-effect is that there are now only two bundled wires from the tail. Less messy.
2. Drilled 6 lightening holes on the prop washer for Neu motor. The drill jig is from DA (for DA85, 100 and 120). A saving of 0.2oz.
3. Redid the back mount plate for Neu. A saving of 0.6oz.
The total saving is 1.4oz = 39grams.
The work done.
#141
NY
Very cool. That couldn't have cost too much. Maybe keep a running tab as you go along.
That must've been one heckuva mondo washer if you could use a DA 120 prop jig!
#142
My Feedback: (90)
You will not believe how strong the washer is until you feel it. I could use a thin one but the motor is positioned such that the collet has to be out that much. A thick washer (like this one) is needed to cover a section of the collet that has no thread!
#143
TX
I think that we accept 5000mah packs as the standard. example.
Rhino 4900 20c packs weigh 1250 grams for a 10S setup ........44.1oz
Skylipo 4400 20c packs weigh 1140 grams for 10S setup ........40.2 oz
I promise you wont see a difference in the lower classes through advanced and honestly havent tried it yet through the masters sequence.
I am currently flying 2 biplanes (Oxai shark and Insightrc Harmony) on 8S setups and am having great success. power is around 2600 watts. If i put this setup in my Pentathlon it would weigh 9 lbs 14 oz.
Chuck Hochhalter
Chuck Hochhalter
#144
ORIGINAL: petec
Geez kinda reminds me of my daughter's husband who told me once that he had a genius IQ and the paperwork to prove it. That's why I've been raising my grandchildren since birth; A freaken deadbeat.....Hmmmm! on second thought maybe the son of a B with an itch is right!?? Nah
#145
NY
#146
My Feedback: (90)
ORIGINAL: RC_Pattern_Flyer
Chuck Hochhalter
Chuck Hochhalter
Should adopt the e-power system earlier, rather than stuck with the ZDZ40, to have much more quality practice time!
#147
NY
I have a pair of the Sky 4400 5S 40C but have not flown them yet. I don't know if hobbypartz is still selling the 20C version, but these 40C's also weigh 570 grams per pack.
#148
ORIGINAL: MTK
1745 grams for engine, CDI, spark plug, prop mounting bolts and washer, header, pipe, soft mount and stand offs and mounting hardware. That's around 3# 14 ozs. A reasonable sum
What's the range of weight for E-Power? That's bats, motor, motor mount hardware, prop mounting hardware and ESC. Judging from some of the battery numbers I saw, we have got to be very close. The main variable will be plane weight but ever there, I don't plan anything more reinforced than typical.
Of course this beastie will be putting out the equivalent of 4500 watts give or take a little
#150
NY
I am flying skylipo 20C 4400 mah.
I can use Gens Ace 30C 5300 mah and be right at the 11lb limit.
Chuck
Chuck
I still didn't get a chance to fly them today because the weather didn't cooperate... not terribly cold, but windy... maybe tomorrow before work.
