CARBON VEIL COVERING AND RADIO INTERFERENCE
My Feedback: (56)
For the BUILDERS out there, a question :
From what I've been told . carbon veil covering on wings and tail feathers can cause radio interference. I'm wondering if anyone out there was either brave/dumb enough or smart enough, depending upon which way you look at it, to give it a try and the results.
I recently covered my new E- Powered U/C Stunter with .02 Carbon Veil and found it to be easy to apply with dope , lightweight and super strong. I detest the current crop of film coverings, all of them, as they wrinkle in the sun and are a maintenance issue. The old stuff was way superior.
Spraying the entire ship like we did back in the day may seem old school to some, but with this material, aircraft weight can be further reduced by virtue of the fact that using it allows for the use of lighter foam wings , stabs , elevators and rudder. Using silkspan is an option;albeit structurally weaker and more difficult to apply.
KS
RE: CARBON VEIL COVERING AND RADIO INTERFERENCE
I've been using carbon veil on my wings for the past 5 or 6 years and never had a problem. The carbon is applied between the foam core and the 1/16th in. sheeting.
Joe Dunnaway.
Joe Dunnaway.
The Black Magic VF3 that Mike Hester Built for me to use in the NATS this past year had Carbon Veil on the Wings. I am using Airtronics gear and have had no problems ( knock on wood)
thank you,
Chris
thank you,
Chris
A few questions please.
What is "carbon veil"?
Where do you get it?
How is it applied? (What adhesive is used?)
JCINTEXAS
JCINTEXAS
My Feedback: (45)
ORIGINAL: cdodom
thank you,
Chris
thank you,
Chris
Arch
ORIGINAL: JCINTEXAS
What is ''carbon veil''?
JCINTEXAS
JCINTEXAS
I am developing a new method of application that should prove even lighter. I will be discussing the techique in my Derivative thread
Carbon makes the balsa skin stiffer so your wings come out stiff and light. With care, the applied material is very light, on par with plastic film, however it takes time and maybe a couple wings to get the techique to that level of perfection
ACP and CST sales both are good sources
My Feedback: (56)
ORIGINAL: cdodom
thank you,
Chris
thank you,
Chris
I use the SD-10G
My Feedback: (29)
Carbon can and will block 2.4. It can effect 72 MHZ too but to a lesser degree. The sailplane guys have been up against this issue for some time now however some of their construction methods are full carbon layups. As for now some sailplanes are offered as " 2.4 friendly " that usually means a slightly heavier fiberglass layup. IMO if there is enough CF in your construction for you to worry about it, mount your antenna(s) outside the airplane. Of course always do a good range check from multiple angles with and without the motor/engine running.
NY
In the sailplane world, a "2.4 friendly" fuselage has a glass nose, with little if any carbon reinforcement surrounding the immediate area where the RX antenna whiskers are.
The best way to deal with large areas of carbon is to have your antenna(s) nowhere near them so they can't be blanked or shadowed in various orientations.
I never really feel confident in any setup with a lot of carbon (or metal, or ignition noise) until I've flown a few flights with a data logger to count frame holds so I know I'm getting the range I need. That's a spektrum accessory but I assume you Futaba guys have a similar feature.
AL
Never experienced any issue with 72 or 2.4 with carbon veil wings or carbon composite fuse construction. Range could be an issue with carbon sail planes as the distance out is greater than we (I) try to fly in pattern.. Although I think I did get scored on site #1 in Muncie last year while flying off site #3 ..
Gary
Gary
It is a Myth.
Ihave a build thread on classic pattern forum of the Zeus 1.20. Ihave referenced to a specific post where you can see the fuse is 100% carbon fiber woven cloth.
These were created in the 90's, and were flown before 2.4 came out, with antenna wire running through the interior of the fuse. Never was there any interference.
Ihave flown these with both 72 and 2.4 systems with rock solid performance.
Dont take my word for it though.. ask TonyF. He had a couple of these as well, and nearly certain at least one of them was full carbon layup as well.
For anyone that looks at that first post of my thread mentioned, the 89 Nats picture of Clayton Foster holding a Zeus, full Carbon fuselage, flew that for years with not one strange radio glitch he can speak of. (with a 72 mHz system((futaba pcm 1024)), antenna ran interior of fuse)
My Feedback: (45)
ORIGINAL: grcourtney
Gary
Gary
Arch
NY
ORIGINAL: Shimano
It is a Myth.
I have a build thread on classic pattern forum of the Zeus 1.20. I have referenced to a specific post where you can see the fuse is 100% carbon fiber woven cloth.
I have flown these with both 72 and 2.4 systems with rock solid performance.
For anyone that looks at that first post of my thread mentioned, the 89 Nats picture of Clayton Foster holding a Zeus, full Carbon fuselage, flew that for years with not one strange radio glitch he can speak of. (with a 72 mHz system ((futaba pcm 1024)), antenna ran interior of fuse)
It is a Myth.
2.4 systems today act just like PCM did in the masking regard, so any failure in the RX link is not going to be "felt" unless it's really bad.
Also keep in mind the thickness and orientation of the carbon in relation to the antenna will have effects on reception. I suspect the carbon veil which started this thread probably isn't thick enough to notice a reduction in range.
I've flown a 3M glass nosed sailplane that went into "full hold" one day at nearly the limit of my eyesight. I was sitting down on the side of a big hill, and when I stood up it luckily regained reception. I landed immediately and noticed the RX antennas had accidentally been folded under the batteries and the remote had slid behind a large area of carbon. Those two culprits caused me to sit up and take notice right away that in my reality carbon blocking is real.
This prompted me to do an exhaustive set of tests with carbon blocking. Documented here:
http://www.rcgroups.com/forums/showthread.php?t=670356
and here:
http://www.rcuniverse.com/forum/m_5738685/tm.htm
I've had similar issues with ignition noise on giant scale installations.
Just saying to not rely on hearsay or lack of "myths." "Keep it real." Do some tests yourself and verify your own installation. It's not that difficult to do a few range checks against a control (out of the airplane situation) and worth not crashing in my opinion.
Joe
My Feedback: (58)
CF can and will shadow and block RF. CF density, power of RF broadcast, relation of CF to RX antenna and it's relation to the TX and RX sensitivity all play major roles in this. Think of it as RF from the TX being water and the CF being screen with varying sized holes in between the TX and the RX with the denser the CF the finer the holes until you finally wind up with enough CF to act as an solid obstruction..
I would not worry about the CF veil being an issue as it's density is not much.
ORIGINAL: petec
[Quote]
I actually did some testing with my old VF3 with a full carbon canopy. I actually put the receiver inside the top of the canopy and then range tested with no issues, and even flew it in this configuration just to see if there were any issues. I never had any issues, so I don't think with the new radio technology that it is a major problem, especially vail in the wings here it is just strips and separated from the RC.
Arch
[ end quote]
Hereby proving you are not only a very good pilot, but brave as well
Brian
ORIGINAL: petec
But I agree that for our purposes, the less carbon around the RX the better is a good rule of thumb.
My Feedback: (58)
ORIGINAL: bjr_93tz
Not quite that simple, otherwise your domestic microwave would have a solid metal front door and not a glass window with a conductive mesh of very carefully sized and spaced holes for the light to come out and the microwaves to stay in.
At any rate, we are in agreement.
My Feedback: (56)
Thanks for the many opinions.
My plan is to use .02 vail on wings, stab, elevator and rudder , only. Many composite molded fuses employ carbon fiber weave strips along seams , several one inch internal ring bands around the fuse for rigidity, sheet / laminate firewalls, gear plates of several variations( sandwich end grain balsa, weave on ply, etc.) for the servo & battery tray .
I don't feel that fuses of that type will have an issue and I believe that actual use history has proven that so.
If I get up the ambition, I'd like to remove the film from the flying surfaces of my old ride( Brio). Sand, dope , vail cover ( no final finish) and fly it with the 2.4 Airtronics RX wire outside the fuse ( probably unnecessary, but for good measure) and see what happens. The ship has served me well for 5 years and if it's lost due to interference, that won't be too devastating.
Because I just converted it from IC to electric, I'm planning to get some trim and reacquaintance flights on it beforehand.
