XIGRIS SERVOS
XIGRIS SERVOS
Hi all,
I am currently building a ZN LINE XIGRIS and I was wondering if my choice of servos was suitable.
I have never used these servos before and I would be greatful of any advice from the experts.
Also any photos of servo instalation will be appreciated.
I am using the following
YS 170 CDI
AILERONS FUTABA BLS 551 X 2
ELEVATOR FUTABA BLS 153 X 2
RUDDER FUTABA BLS 452
Thank you in advance
MAVROS
AUSTRALIA
YS 170 CDI
MAVROS
AUSTRALIA
RE: XIGRIS SERVOS
MAVROS,
That will work just fine! I use basically the same servos in a Futaba digital, but not the BLS series. They were just coming out when I finished my planes in 2008.
Best of luck with the plane. [8D]
bholsten
bholsten
RE: XIGRIS SERVOS
MAVROS,
Also beware, with the YS 170 and two mini servos in the stab they are going to wear out from the vibration, if you fly alot. Most guys run the DPS single servo system with the YS. I had about 50 flights on my primary plane before I converted it over from the YS 170 to EP and my servos were fine in the stabs.
Just be aware over time you will have to replace them as the gear train gets sloppy.
bholsten
bholsten
RE: XIGRIS SERVOS
Thanks Bill
I am inclined to use the MK Dual elevator system......works fine in the Zeque
However I am a bit concerned about CoG issiues without the 2 servos at the back
regards
Mavros
regards
Mavros
